Control of collective dynamics with time-varying weights - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Springer INdAM Series Année : 2021
This paper focuses on a model for opinion dynamics, where the influence weights of agents evolve in time. We formulate a control problem of consensus type, in which the objective is to drive all agents to a final target point under suitable control constraints. Controllability is discussed for the corresponding problem with and without constraints on the total mass of the system, and control strategies are designed with the steepest descent approach. The mean-field limit is described both for the opinion dynamics and the control problem. Numerical simulations illustrate the control strategies for the finite-dimensional system.
ControlMass_Indam.pdf (702 Ko) Télécharger le fichier
hal-02995844 , version 1 (09-11-2020)
hal-02995844 , version 2 (24-03-2021)
Nastassia Pouradier Duteil, Benedetto Piccoli. Control of collective dynamics with time-varying weights. Springer INdAM Series, 2021. ⟨hal-02995844v2⟩
79 Consultations
63 Téléchargements
