C source-to-source compiler enhancement from within - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
Amélioration source-à-source de compilateurs C
We show how locally replaceable code snippets can be used to easily specify and prototype compiler and language enhancements for the C language that work by local source-to-source transformation. A toolbox implements the feature and provides many directives that can be used for compile time configuration and tuning, code unrolling, compile time expression evaluation and program modularization. The tool is also easily extensible by simple filters that can be programmed with any suitable text processing framework.
RR-9375.pdf (870.45 Ko) Télécharger le fichier
hal-02998412 , version 1 (10-11-2020)
hal-02998412 , version 2 (17-11-2020)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-02998412 , version 2
Jens Gustedt. C source-to-source compiler enhancement from within. [Research Report] RR-9375, INRIA. 2020. ⟨hal-02998412v2⟩
7029 Consultations
1038 Téléchargements
