, Consuming Web Services Made with HTTP-GET, HTTP-POST, and SOAP, .NET Programming with Visual C++, pp.552-589, 2003.
, OpenScop, 2014.
WRF-CMake: integrating CMake support into the Advanced Research WRF (ARW) modelling system, Journal of Open Source Software, vol.4, issue.41, p.1468, 2019. ,
Acknowledgments, Journal of Gerontology, vol.48, issue.3, pp.P99-P99, 1993. ,
A Domain-Specific Language and Compiler for Stencil Computations on Short-Vector SIMD and GPU Architectures, Compilers for Parallel Computing Workshop, 2013. ,
, 2020. ISO/IEC 9899 working draft February 2020. Number ISO/IEC 9899
, 2018. Programming languages -C
Programming Parallel Applications in Cilk, 1997. ,
, The Open Group Base Specifications, 2018.
, A Quick Reference to OpenMP, Parallel Programming in OpenMP, pp.211-216, 2001.
, Boris Johnson announces £1.8bn funding boost for the NHS, The Pharmaceutical Journal, 2019.
Coding stencil computations using the pochoir stencilspecification language, USENIX Workshop on Hot Topics in Parallelism. RR n°9375 RESEARCH CENTRE NANCY -GRAND EST 615 rue du Jardin Botanique CS20101 54603 Villers-lès-Nancy Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria.fr ISSN, pp.249-6399, 2011. ,
