Sediment mining in alluvial channels: physical effects and management perspectives, River Research and Applications, vol.21, issue.7, pp.805-828, 2005. ,
, Potholes in Shikoku, Japan, Part 1. Potholes and their hydrodynamics in Kurakawa River, Ehime. Memoirs of the Faculty of Science, vol.7, pp.127-190, 1987.
Laboratory tools to quantify biogenic dissolution of rocks and minerals: a model rock biofilm growing in percolation columns, Frontiers in Earth Science, vol.4, issue.31, 2016. ,
Evaluation of the role of rock properties in the development of potholes: A case study of the Indrayani knickpoint, Maharashtra, Journal of Earth System Science, vol.120, issue.1, pp.157-165, 2011. ,
River longitudinal profiles and bedrock incision models: Stream power and the influence of sediment supply, Rivers Over Rock: Fluvial Processes in Bedrock Channels, pp.237-260, 1998. ,
Sediment and rock strength controls on river incision into bedrock, Geology, vol.29, issue.12, p.1087, 2001. ,
Empirical and theoretical investigations of sculpted forms in Buckeye Creek Cave, West Virginia, Journal of Geology, vol.110, pp.469-481, 2002. ,
Dynamics of pothole growth as defined by field data and geometrical description, Journal of Geophysical Research: Earth Surface, vol.110, issue.F4, pp.n/a-n/a, 2005. ,
Theoretical modeling of stream potholes based upon empirical observations from the Orange River, Republic of South Africa, Geomorphology, vol.82, issue.1-2, pp.160-176, 2006. ,
Regulated Rivers : Research & Management, Channelization and consequences on floodplain system functioning on the Garonne River, vol.14, pp.13-23, 1998. ,
Les ajustements morphologiques contemporains du lit mineur de la Garonne, France et leurs effets sur l'hydrosystème fluvial, Zeitschrift für Geomorphologie, vol.122, pp.227-246, 2000. ,
Formations molassiques du Bassin aquitain : cartographie géologique à l'aide des images prises par satellites, Revue géographique des Pyrénées et du Sud-Ouest, vol.55, issue.1, pp.29-48, 1984. ,
Quantitative methods in Geography: an introduction to spatial analysis, vol.386, 1977. ,
Field studies of bedrock channels, Rivers Over Rock: Fluvial Processes in Bedrock Channels, vol.30, pp.261-277, 1998. ,
Construction géohistorique du « sauvage » de la Garonne toulousaine : quelle part de naturalité dans les paysages fluviaux ? (2ème partie), Développement durable et territoires, vol.5, issue.Vol. 5, n°3, pp.1-22, 2014. ,
Formation and development of stream potholes in a gorge in Guangdong, Journal of Geographical Sciences, vol.19, issue.1, pp.118-128, 2009. ,
River incision into bedrock: Mechanics and relative efficacy of plucking, abrasion, and cavitation, Geological Society of America Bulletin, vol.112, issue.3, pp.490-503, 2000. ,
The origin and role of biological rock crusts in rocky desert weathering, Biogeosciences, vol.16, pp.1133-1145, 2018. ,
Bedrock channel incision along Picanniny Creek, Australia. Journal of Geology, vol.101, issue.6, pp.749-761, 1993. ,
Particle dynamics: The continuum of bedrock to alluvial river segments, Geomorphology, vol.241, pp.192-208, 2015. ,
Possible hydraulic significance of two kinds of potholes: Examples from the paleo-Potomac River, Geology, vol.22, issue.1, p.47, 1994. ,
