New interface
Reports (Research report)
Group design in group testing for COVID-19 : A French case-study
Tifaout Almeftah 1 Luce Brotcorne 1 Diego Cattaruzza 2 Bernard Fortz 1 Kaba Keita 1 Martine Labbé 1 Maxime Ogier 1 Frédéric Semet 1
1 INOCS - Integrated Optimization with Complex Structure
Inria Lille - Nord Europe, ULB - Université libre de Bruxelles, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : Group testing is a screening strategy that involves dividing a population into several disjointed groups of subjects. In its simplest implementation, each group is tested with a single test in the first phase, while in the second phase only subjects in positive groups, if any, need to be tested again individually. In this paper, we address the problem of group testing design, which aims to determine a partition into groups of a finite population in such a way that cardinality constraints on the size of each group and a constraint on the expected total number of tests are satisfied while minimizing a linear combination of the expected number of false negative and false positive classifications. First, we show that the properties and model introduced by Aprahmian et al. can be extended to the group test design problem, which is then modeled as a constrained shortest path problem on a specific graph. We design and implement an ad hoc algorithm to solve this problem. On instances based on Santé Publique France data on Covid-19 screening tests, the results of the computational experiments are very promising.
Document type :
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-03000715
Contributor : Frédéric Semet Connect in order to contact the contributor
Submitted on : Thursday, November 12, 2020 - 9:39:39 AM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Saturday, February 13, 2021 - 6:37:52 PM
File
GroupTesting.pdf
Identifiers
  • HAL Id : hal-03000715, version 1
Citation
Tifaout Almeftah, Luce Brotcorne, Diego Cattaruzza, Bernard Fortz, Kaba Keita, et al.. Group design in group testing for COVID-19 : A French case-study. [Research Report] INRIA - Centre Lille Nord Europe. 2020. ⟨hal-03000715⟩
Share
Metrics
Record views
558
Files downloads
406
