Deep Geometric Functional Maps: Robust Feature Learning for Shape Correspondence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel learning-based approach for computing correspondences between non-rigid 3D shapes. Unlike previous methods that either require extensive training data or operate on handcrafted input descriptors and thus generalize poorly across diverse datasets, our approach is both accurate and robust to changes in shape structure. Key to our method is a feature-extraction network that learns directly from raw shape geometry, combined with a novel reg-ularized map extraction layer and loss, based on the functional map representation. We demonstrate through extensive experiments in challenging shape matching scenarios that our method can learn from less training data than existing supervised approaches and generalizes significantly better than current descriptor-based learning methods. Our source code is available at: https://github.com/ LIX-shape-analysis/GeomFmaps.
deepgeofmap.pdf (6.12 Mo) Télécharger le fichier
hal-03001057 , version 1 (12-11-2020)
  • HAL Id : hal-03001057 , version 1
Nicolas Donati, Abhishek Sharma, Maks Ovsjanikov. Deep Geometric Functional Maps: Robust Feature Learning for Shape Correspondence. CVPR, Jun 2020, Seattle (virtual), United States. ⟨hal-03001057⟩
98 Consultations
98 Téléchargements
