Asymptotic derivation and simulations of a non-local Exner model in large viscosity regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2021
The present paper deals with the modeling and numerical approximation of bed load transport under the action of water. A new shallow water type model is derived from the stratified two-fluid Navier–Stokes equations. Its novelty lies in the magnitude of a viscosity term that leads to a momentum equation of elliptic type. The full model, sediment and water, verifies a dissipative energy balance for smooth solutions. The numerical resolution of the sediment layer is not trivial since the viscosity introduces a non-local term in the model. Adding a transport threshold makes the resolution even more challenging. A scheme based on a staggered discretization is proposed for the full model, sediment and water.
m2an200222.pdf (2.37 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03312836 , version 1 (02-08-2021)
Emmanuel Audusse, Léa Boittin, Martin Parisot. Asymptotic derivation and simulations of a non-local Exner model in large viscosity regime. ESAIM: Mathematical Modelling and Numerical Analysis, 2021, 55 (4), pp.1635-1668. ⟨10.1051/m2an/2021031⟩. ⟨hal-03312836⟩
219 Consultations
132 Téléchargements
