New interface
Journal articles
Random Walk in a N-Cube Without Hamiltonian Cycle to Chaotic Pseudorandom Number Generation: Theoretical and Practical Considerations
Abstract : Designing a pseudorandom number generator (PRNG) is a difficult and complex task. Many recent works have considered chaotic functions as the basis of built PRNGs: the quality of the output would indeed be an obvious consequence of some chaos properties. However, there is no direct reasoning that goes from chaotic functions to uniform distribution of the output. Moreover, embedding such kind of functions into a PRNG does not necessarily allow to get a chaotic output, which could be required for simulating some chaotic behaviors. In a previous work, some of the authors have proposed the idea of walking into a N-cube where a balanced Hamiltonian cycle has been removed as the basis of a chaotic PRNG. In this article, all the difficult issues observed in the previous work have been tackled. The chaotic behavior of the whole PRNG is proven. The construction of the balanced Hamiltonian cycle is theoretically and practically solved. An upper bound of the expected length of the walk to obtain a uniform distribution is calculated. Finally practical experiments show that the generators successfully pass the classical statistical tests.
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-03003541
Contributor : Sylvain Contassot-Vivier Connect in order to contact the contributor
Submitted on : Friday, November 13, 2020 - 12:05:58 PM
Last modification on : Thursday, January 13, 2022 - 12:00:27 PM
Long-term archiving on: : Sunday, February 14, 2021 - 6:44:50 PM
File
ContassotCouchotGuyeuxHeam2017...
Identifiers
Citation
Sylvain Contassot-Vivier, Jean-François Couchot, Christophe Guyeux, Pierre-Cyrille Heam. Random Walk in a N-Cube Without Hamiltonian Cycle to Chaotic Pseudorandom Number Generation: Theoretical and Practical Considerations. International journal of bifurcation and chaos in applied sciences and engineering , 2017, 27 (01), pp.1750014. ⟨10.1142/S0218127417500146⟩. ⟨hal-03003541⟩
Share
Metrics
Record views
182
Files downloads
158
