Floating Potential Boundary Condition in Smooth Domains in an Electroporation Context - Archive ouverte HAL Access content directly
Conference Papers Year : 2021
(1) , (1) , (1)
1
In electromagnetism, a conductor that is not connected to the ground is an equipo-tential whose value is implicitly determined by the constraint of the problem. It leads to a non-local constraints on the flux along the conductor interface, so-called floating potential problems. Unlike previous numerical study that tackle the floating potential problems with the help of advanced and complex numerical methods, we show how an appropriate use of Steklov-Poincaré operators enables to obtain the solution to this partial differential equations with a non local constraint as a linear (and well-designed) combination of N + 1 Dirichlet problems, N being the number of conductors not connected to a ground potential. In the case of thin highly conductive inclusion, we perform an asymptotic analysis to approach the electroquasistatic potential at any order of accuracy. In particular, we show that the so-called floating potential approaches the electroquasistatic potential with a first order accuracy. This enables us to characterize the configurations for which floating potential approximation has to be used to accurately solve the electroquasistatic problem.
FloatingPotential-revised.pdf (581.9 Ko) Télécharger le fichier
Dates and versions
hal-03004806 , version 1 (13-11-2020)
hal-03004806 , version 2 (23-01-2023)
Identifiers
Cite
Annabelle Collin, Sergio Corridore, Clair Poignard. Floating Potential Boundary Condition in Smooth Domains in an Electroporation Context. MMDS 2020 - International Conference by Center for Mathematical Modeling and Data Science, Oct 2020, Osaka (JP), Japan. pp.91-106, ⟨10.1007/978-981-16-4866-3_6⟩. ⟨hal-03004806v2⟩
44 View
101 Download
Share
