Preprints, Working Papers, ...
Tracing isomanifolds in $R^d$ in time polymonial in d
Abstract : Isomanifolds are the generalization of isosurfaces to arbitrary dimension and codimension, i.e. submanifolds of R d defined as the zero set of some multivariate multivalued smooth function $f : R^d → R^{d−n}$ , where n is the intrinsic dimension of the manifold. A natural way to approximate a smooth isomanifold M is to consider its Piecewise-Linear (PL) approximationM based on a triangulation T of the ambient space $R^d$. In this paper, we describe a simple algorithm to trace isomanifolds from a given starting point. The algorithm works for arbitrary dimensions n and d, and any precision D. Our main result is that, when f (or M) has bounded complexity, the complexity of the algorithm is polynomial in d and $δ = 1/D$ (and unavoidably exponential in n). Since it is known that for $δ = Ω(d^{2.5}),$M is $O(D^2)$-close and isotopic to M, our algorithm produces a faithful PL-approximation of isomanifolds of bounded complexity in time polynomial in d. Combining this algorithm with dimensionality reduction techniques, the dependency on d in the size of M can be completely removed with high probability. We also show that the algorithm can handle isomanifolds with boundary and, more generally, isostratifolds. The algorithm has been implemented and experimental results are reported, showing that it is practical and can handle cases that are far ahead of the state-of-the-art.
Complete list of metadata
Cited literature [3 references]  Display  Hide  Download
https://hal.inria.fr/hal-03006663
Contributor : Jean-Daniel Boissonnat Connect in order to contact the contributor
Submitted on : Monday, November 16, 2020 - 9:12:13 AM
Last modification on : Thursday, March 18, 2021 - 3:31:17 AM
Long-term archiving on: : Wednesday, February 17, 2021 - 6:21:55 PM
File
SoCGTracing.pdf
Identifiers
  • HAL Id : hal-03006663, version 1
Citation
Jean-Daniel Boissonnat, Siargey Kachanovich, Mathijs Wintraecken. Tracing isomanifolds in $R^d$ in time polymonial in d. 2020. ⟨hal-03006663v1⟩
Share
Metrics
Record views
230
Files downloads
265
