Brief Announcement: Phase Transitions of the $k$-Majority Dynamics in a Biased Communication Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We analyze the binary-state (either $R$ or $B$ ) $k$-majority dynamics in a biased communication model where nodes have some fixed probability $p$, independent of the dynamics, of being seen in state $B$ by their neighbors. In this setting we study how $p$, as well as the initial unbalance between the two states, impact on the speed of convergence of the process, identifying sharp phase transitions.
main.pdf (237.97 Ko) Télécharger le fichier
hal-03007234 , version 1 (11-12-2020)
  • HAL Id : hal-03007234 , version 1
Emilio Cruciani, Hlafo Alfie Mimun, Matteo Quattropani, Sara Rizzo. Brief Announcement: Phase Transitions of the $k$-Majority Dynamics in a Biased Communication Model. DISC 2020 - 34th International Symposium on Distributed Computing, Oct 2020, Freibourg / Virtual, Germany. ⟨hal-03007234⟩
63 Consultations
58 Téléchargements
