Quadratic order conditions for bang-singular extremals, Numerical Algebra, Control and Optimization, vol.2, issue.3, pp.511-546, 2012. ,
Second order analysis of control-affine problems with scalar state constraint, Mathematical Programming, vol.160, issue.1-2, pp.115-147, 2016. ,
Correction to: Optimal control of infinite dimensional bilinear systems: application to the heat and wave equations, Mathematical Programming, vol.170, issue.2, pp.569-570, 2018. ,
Optimal Control of PDEs in a Complex Space Setting: Application to the Schrödinger Equation, SIAM Journal on Control and Optimization, vol.57, issue.2, pp.1390-1412, 2019. ,
State-Constrained Control-Affine Parabolic Problems I: First and Second Order Necessary Optimality Conditions, Set-Valued and Variational Analysis, vol.849, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-03011004
Singular arcs in the optimal control of a parabolic equation, 2013 European Control Conference (ECC), pp.281-292, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00845704
, 11th IFAC International Workshop on Adaptation and Learning in Control and Signal Processing, 2013, Proc 11th IFAC Workshop on Adaptation and Learning in Control and Signal Processing, vol.852, 2013.
Second Order Analysis for Bang-Bang Control Problems of PDEs, SIAM Journal on Control and Optimization, vol.50, issue.4, pp.2355-2372, 2012. ,
Sufficient Second-Order Optimality Conditions for Semilinear Control Problems with Pointwise State Constraints, SIAM Journal on Optimization, vol.19, issue.2, pp.616-643, 2008. ,
Second Order and Stability Analysis for Optimal Sparse Control of the FitzHugh--Nagumo Equation, SIAM Journal on Control and Optimization, vol.53, issue.4, pp.2168-2202, 2015. ,
Second-Order Analysis and Numerical Approximation for Bang-Bang Bilinear Control Problems, SIAM Journal on Control and Optimization, vol.56, issue.6, pp.4203-4227, 2018. ,
Optimality conditions for state-865 constrained PDE control problems with time-dependent controls, Control and Cybernetics, vol.866, pp.5-38, 2008. ,
Necessary Conditions for Singular Extremals Involving Multiple Control Variables, SIAM Journal on Control, vol.4, issue.4, pp.716-731, 1966. ,
Second Order Sufficient Optimality Conditions for Parabolic Optimal Control Problems with Pointwise State Constraints, SIAM Journal on Control and Optimization, vol.51, issue.1, pp.304-331, 2013. ,
Problèmes aux limites non homogènes (VI), Journal d'Analyse Mathématique, vol.11, issue.1, pp.165-188, 1963. ,
, , 1968.
Second order sufficient optimality conditions for nonlinear parabolic control problems with state constraints, Discrete & Continuous Dynamical Systems - A, vol.6, issue.2, pp.431-450, 2000. ,
Sufficient Second-Order Optimality Conditions for a Parabolic Optimal Control Problem with Pointwise Control-State Constraints, SIAM Journal on Control and Optimization, vol.42, issue.1, pp.138-154, 2003. ,
