Faster Enumeration-Based Lattice Reduction: Root Hermite Factor $k^{1/(2k)}$ Time $k^{k/8+o(k)}$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We give a lattice reduction algorithm that achieves root Hermite factor k1/(2k) in time kk/8+o(k) and polynomial memory. This improves on the previously best known enumeration-based algorithms which achieve the same quality, but in time kk/(2e)+o(k) . A cost of kk/8+o(k) was previously mentioned as potentially achievable (Hanrot-Stehlé’10) or as a heuristic lower bound (Nguyen’10) for enumeration algorithms. We prove the complexity and quality of our algorithm under a heuristic assumption and provide empirical evidence from simulation and implementation experiments attesting to its performance for practical and cryptographic parameter sizes. Our work also suggests potential avenues for achieving costs below kk/8+o(k) for the same root Hermite factor, based on the geometry of SDBKZ-reduced bases.
Fichier non déposé
hal-03011699 , version 1 (18-11-2020)
Martin Albrecht, Shi Bai, Pierre-Alain Fouque, Paul Kirchner, Damien Stehlé, et al.. Faster Enumeration-Based Lattice Reduction: Root Hermite Factor $k^{1/(2k)}$ Time $k^{k/8+o(k)}$. Crypto, 2020, Santa Barbara, United States. pp.186-212, ⟨10.1007/978-3-030-56880-1_7⟩. ⟨hal-03011699⟩
78 Consultations
0 Téléchargements
