Minimal diameter double-loop networks: Dense optimal families - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks Année : 1991
This article deals with the problem of minimizing the transmission delay in Illiac-type interconnection networks for parallel or distributed architectures or in local area networks. A double-loop networks (also known as circulant) G (n,h) consist of a loop of n vertices where each vertex i is also joined by chords to the vertices i +- h mod n. An integer n, a hop h, and a network (G(n,h) are called optimal if the diameter of G (n,h) is equal to the lower bound k when n E R [k] = (2k2 - 2K +2, ..., 2k2 + 2K+1). We determine new dense families of values of n that are optimal and such that the computation of the optimal hop is easy. These families cover almost all the elements of R[k] if k +1 is prime and cover 92% of all values of n up to 10(6).
78-BeTz91.pdf (2.47 Mo) Télécharger le fichier
hal-03013377 , version 1 (18-11-2020)
Jean-Claude Bermond, Dvora Tzvieli. Minimal diameter double-loop networks: Dense optimal families. Networks, 1991, 21 (1), pp.1-9. ⟨10.1002/net.3230210102⟩. ⟨hal-03013377⟩
35 Consultations
58 Téléchargements
