Decomposition into cycles I: Hamilton decompositions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1987
In this part we survey the results concerning the partitions of the edge-set of a graph into Hamilton cycles or into Hamilton cycles and a single perfect matching.
73-ABS90-Decompositions cycles .pdf (4.42 Mo) Télécharger le fichier
hal-03013446 , version 1 (18-11-2020)
  • HAL Id : hal-03013446 , version 1
Brian Alspach, Jean-Claude Bermond, Dominique Sotteau. Decomposition into cycles I: Hamilton decompositions. Workshop on Cycles and Rays, 1987, Montreal, Canada. pp.9-18. ⟨hal-03013446⟩
23 Consultations
207 Téléchargements
