An a posteriori-based adaptive preconditioner for controlling a local algebraic error norm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BIT Numerical Mathematics Année : 2021
This paper introduces an adaptive preconditioner for iterative solution of sparse linear systems arising from partial differential equations with self-adjoint operators. This preconditioner allows to control the growth rate of a dominant part of the algebraic error within a fixed point iteration scheme. Several numerical results that illustrate the efficiency of this adaptive preconditioner with a PCG solver are presented and the preconditioner is also compared with a previous variant in the literature.
An a posteriori-based adaptive preconditioner for controlling a local algebraic error norm.pdf (862.99 Ko) Télécharger le fichier
hal-03013484 , version 1 (19-11-2020)
Ani Anciaux-Sedrakian, Laura Grigori, Zakariae Jorti, Soleiman Yousef. An a posteriori-based adaptive preconditioner for controlling a local algebraic error norm. BIT Numerical Mathematics, 2021, 61 (1), pp.209-235. ⟨10.1007/s10543-020-00822-3⟩. ⟨hal-03013484⟩
104 Consultations
148 Téléchargements
