An elastic framework for ensemble-based large-scale data assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
Prediction of chaotic systems relies on a floating fusion of sensor data (observations) with a numerical model to decide on a good system trajectory and to compensate nonlinear feedback effects. Ensemble-based data assimilation (DA) is a major method for this concern depending on propagating an ensemble of perturbed model realizations. In this paper we develop an elastic, online, fault-tolerant and modular framework called Melissa-DA for large-scale ensemble-based DA. Melissa-DA allows elastic addition or removal of compute resources for state propagation at runtime. Dynamic load balancing based on list scheduling ensures efficient execution. Online processing of the data produced by ensemble members enables to avoid the I/O bottleneck of file-based approaches. Our implementation embeds the PDAF parallel DA engine, enabling the use of various DA methods. Melissa-DA can support extra ensemble-based DA methods by implementing the transformation of member background states into analysis states. Experiments confirm the excellent scalability of Melissa-DA, running on up to 16,240 cores, to propagate 16,384 members for a regional hydrological critical zone assimilation relying on the ParFlow model on a domain with about 4 M grid cells.
RR-9377.pdf (960.03 Ko) Télécharger le fichier
hal-03017033 , version 1 (20-11-2020)
hal-03017033 , version 2 (24-11-2020)
hal-03017033 , version 3 (14-06-2022)
Sebastian Friedemann, Bruno Raffin. An elastic framework for ensemble-based large-scale data assimilation. [Research Report] RR-9377, INRIA : Institut national de recherche en sciences et technologies du numérique. 2020, pp.1-28. ⟨hal-03017033v2⟩
840 Consultations
367 Téléchargements
