Mixing strategies combined with shape design to enhance productivity of a raceway pond - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper focuses on mixing strategies and designing shape of the bottom topographies to enhance the growth of the microalgae in raceway ponds. A physical-biological coupled model is used to describe the growth of the algae. A simple model of a mixing device such as a paddle wheel is also considered. The complete process model was then included in an optimization problem associated with the maximization of the biomass production. The results show that non-trivial topographies can be coupled with some specific mixing strategies to improve the microalgal productivity.
hal.pdf (819.88 Ko) Télécharger le fichier
hal-03017414 , version 1 (20-11-2020)
Olivier Bernard, Liu-Di Lu, Julien Salomon. Mixing strategies combined with shape design to enhance productivity of a raceway pond. ADCHEM 2021 - 16th IFAC Symposium on Advanced Control of Chemical Processes, Jun 2021, Venice, Italy. pp.281-286, ⟨10.1016/j.ifacol.2021.08.255⟩. ⟨hal-03017414⟩
136 Consultations
52 Téléchargements
