Abstract : This paper deals with the problem of robust H∞ model reduction for two-dimensional (2D) continuous systems described by Roesser model with polytopic uncertainties, over finite frequency (FF) domain. The problem to be solved in the paper is to find a reduced-order model such that the approximation error system is asymptotically stable, which is able to approximate the original continuous systems system with comparatively small and minimised H∞ performance when frequency ranges of noises are known beforehand. Via the use of the generalised Kalman Yakubovich Popov (gKYP) lemma, homogeneous polynomially parameter-dependent matrices, Finsler's lemma and we introduce many slack matrices, sufficient conditions for the existence of H∞ model reduction for different FF ranges are proposed and then unified in terms of solving a set of linear matrix inequalities (LMIs). To highlight the effectiveness of the proposed H∞ model reduction design, two illustrative examples are given.
