Differentiable simulation for physical system identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2021
Simulating frictional contacts remains a challenging research topic in robotics. Recently, differentiable physics emerged and has proven to be a key element in modelbased Reinforcement Learning (RL) and optimal control fields. However, most of the current formulations deploy coarse approximations of the underlying physical principles. Indeed, the classic simulators lose precision by casting the Nonlinear Complementarity Problem (NCP) of frictional contact into a Linear Complementarity Problem (LCP) to simplify computations. Moreover, such methods deploy non-smooth operations and cannot be automatically differentiated. In this paper, we propose (i) an extension of the staggered projections algorithm for more accurate solutions of the problem of contacts with friction. Based on this formulation, we introduce (ii) a differentiable simulator and an efficient way to compute the analytical derivatives of the involved optimization problems. Finally, (iii) we validate the proposed framework with a set of experiments to present a possible application of our differentiable simulator. In particular, using our approach we demonstrate accurate estimation of friction coefficients and object masses both in synthetic and real experiments.
lelidec2020diffsim.pdf (991.36 Ko) Télécharger le fichier
hal-03025616 , version 1 (26-11-2020)
hal-03025616 , version 2 (12-02-2021)
hal-03025616 , version 3 (04-03-2021)
Quentin Le Lidec, Igor Kalevatykh, Ivan Laptev, Cordelia Schmid, Justin Carpentier. Differentiable simulation for physical system identification. IEEE Robotics and Automation Letters, 2021, 6 (2), pp.3413-3420. ⟨10.1109/LRA.2021.3062323⟩. ⟨hal-03025616v3⟩
863 Consultations
1301 Téléchargements
