Numeric Domains Meet Algebraic Data Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We report on the design and formalization of a novel abstract domain, called numeric path relations (NPRs), that combines numeric relational domains with algebraic data types. This domain expresses relations between algebraic values that can contain scalar data. The construction of the domain is parameterized by the choice of a relational domain on scalar values. The construction employs projection paths on algebraic values, and in particular projections on variant cases, whose sound treatment is subtle due to mutual exclusiveness.
nsad2020_NPRs.pdf (597.68 Ko) Télécharger le fichier
hal-03028476 , version 1 (27-11-2020)
Santiago Bautista, Thomas Jensen, Benoît Montagu. Numeric Domains Meet Algebraic Data Types. NSAD 2020 - 9th International Workshop on Numerical and Symbolic Abstract Domains, Nov 2020, Virtual, United States. pp.12-16, ⟨10.1145/3427762.3430178⟩. ⟨hal-03028476⟩
164 Consultations
194 Téléchargements
