Abstract : Despite the insight of some of the pioneers (Turing, von Neumann, Curry, Böhm), programming the early computers was a matter of fiddling with small architecture-dependent details. Only in the sixties some form of "mathematical program development" will be in the agenda of some of the most influential players of that time. A "Mathematical Theory of Computation" is the name chosen by John McCarthy for his approach, which uses a class of recursively computable functions as an (extensional) model of a class of programs. It is the beginning of that grand endeavour to present programming as a mathematical activity, and reasoning on programs as a form of mathematical logic. An important part of this process is the standard model of programming languages-the informal assumption that the meaning of programs should be understood on an abstract machine with unbounded resources, and with true arithmetic. We present some crucial moments of this story, concluding with the emergence, in the seventies, of the need of more "intensional" semantics, like the sequential algorithms on concrete data structures. The paper is a small step of a larger project-reflecting and tracing the interaction between mathematical logic and programming (languages), identifying some of the driving forces of this process. To Maurizio Gabbrielli, on his 60th birthday
