Mathematical programming formulations for the alternating current optimal power flow problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue 4OR: A Quarterly Journal of Operations Research Année : 2020
Power flow refers to the injection of power on the lines of an electrical grid, so that all the injections at the nodes form a consistent flow within the network. Optimality, in this setting, is usually intended as the minimization of the cost of generating power. Current can either be direct or alternating: while the former yields approximate linear programming formulations, the latter yields formulations of a much more interesting sort: namely, nonconvex nonlinear programs in complex numbers. In this technical survey, we derive formulation variants and relaxations of the alternating current optimal power flow problem.
4or19.pdf (606.11 Ko) Télécharger le fichier
hal-03030149 , version 1 (29-11-2020)
Dan Bienstock, Mauro Escobar, Claudio Gentile, Leo Liberti. Mathematical programming formulations for the alternating current optimal power flow problem. 4OR: A Quarterly Journal of Operations Research, 2020, 18 (3), pp.249-292. ⟨10.1007/s10288-020-00455-w⟩. ⟨hal-03030149⟩
52 Consultations
217 Téléchargements
