Construire une ontologie des expériences de lecture : un cas de réutilisation du CIDOC CRM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Reading Experience Ontology (REO): Reusing and Extending CIDOC CRM
This paper aims to present the development strategy of the ontology proposed in the READ-IT project (https://readit-project.eu) and the contributions it makes to the conceptual description of reading experiences and, more broadly, to the description of intangible heritage and other "experiential" phenomena. Its development relied on a data-driven approach with the active participation of a representative panel of reading experts from HSS disciplines. The process was iterative to converge towards a consensus balancing ICT requirements and HSS scholar needs. In this regard, we will focus on the general framework and the way in which both alignments of CIDOC CRM (and some of its extensions) with READ-IT’s data model and creations of classes have been carried out, as well as the benefits derived from a pragmatic and cost-efficient approach, allowing us to offer REO as an extension of CIDOC CRM, which will guarantee its reusability, improvement and maintenance over time.
Cette communication a pour objectif de présenter la stratégie de développement de l’ontologie proposée dans le cadre du projet READ-IT ainsi que ses apports à la description conceptuelle des expériences de lecture, et plus largement à celle du patrimoine immatériel et des autres phénomènes « expérientiels ».
DH2020_short_paper_Vignale_Antonini_Gravier.pdf (134.19 Ko) Télécharger le fichier
hal-03033225 , version 1 (01-12-2020)
  • HAL Id : hal-03033225 , version 1
François Vignale, Alessio Antonini, Guillaume Gravier. Construire une ontologie des expériences de lecture : un cas de réutilisation du CIDOC CRM. DH 2020 - Conference on Digital Humanities, Jul 2020, Ottawa, Canada. pp.1-3. ⟨hal-03033225⟩
79 Consultations
77 Téléchargements
