Providing Software Asset Management Compliance in Green Deployment Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Today, the use of software is generally regulated by licenses, whether they are free or paid and with or without access to their sources. The world of licenses is very vast and unknown. Often only the public version is known (a software purchase corresponds to a license). For enterprises, the reality is much more complex, especially for main software publishers. Very few, if any, deployment algorithm takes Software Asset Management (SAM) considerations into account when placing software on Cloud architecture. This could have huge financial impact on the company using theses software. In this article, we present the SAM problem more deeply, then, after expressing our problem mathematically, we present GreenSAM, our multi-parametric heuristic handling performance and energy parameters as well as SAM considerations. We will then show the use of this heuristic on two realistic situations, first with an Oracle Database deployment and second with a larger scenario of managing a small OpenStack platform deployment. In both cases, we will compare GreenSAM with other heuristics to show how it handles the performance/energy criteria and the SAM compliance.
SETCAC_2020 - Providing Software Asset Management Compliance in Green Deployment Algorithm.pdf (614.66 Ko) Télécharger le fichier
hal-03034059 , version 1 (01-12-2020)
  • HAL Id : hal-03034059 , version 1
Noëlle Baillon-Bachoc, Eddy Caron, Arthur Chevalier, Anne-Lucie Vion. Providing Software Asset Management Compliance in Green Deployment Algorithm. SETCAC 2020 - Symposium on Emerging Topics in Computing and Communications, Oct 2020, Chennai, India. pp.1-14. ⟨hal-03034059⟩
93 Consultations
263 Téléchargements
