Abstract : The development of Cyber-Physical Systems involves several disciplines and stakeholders, which use heterogeneous models and formalisms to specify the system and make early validation and verification. In order to understand the behaviour emerging from the heterogeneous models, a collaborative simulation (co-simulation) can be used. To make it happen, the system engineer must define a correct coordination of the different executable models, which can be distributed over different enterprises. This is an important but difficult (and error prone) task that can not be done without information about the behavioral semantics of each model. In this paper, we introduce an integrated development environment which allows 1) to import different executable models (named simulation units), 2) to graphically connect them with rich connectors and 3) to generate a dedicated, accurate and efficient distributed co-simulation. The framework is based on Eclipse EMF for the modeling part and on ∅MQ for the deployment. It is named CoSim20.
