Kombinierte Abschätzung des Materialgesetzes und der unbelasteten Konfiguration (Anwendung auf die Lungenporomechanik)
Combined Estimation of Material Law and Unloaded Configuration (Application to Pulmonary Poro-Mechanics)
Estimation combinée de la loi des matériaux et de la configuration déchargée (application à la poromécanique pulmonaire)
Domains
Engineering Sciences [physics] Mechanics [physics.med-ph] Mechanical engineering [physics.class-ph] Engineering Sciences [physics] Mechanics [physics.med-ph] Biomechanics [physics.med-ph] Engineering Sciences [physics] Mechanics [physics.med-ph] Solid mechanics [physics.class-ph] Computer Science [cs] Numerical Analysis [cs.NA]
Combined Estimation of Material Lawand Unloaded Configuration.pdf (3.31 Mo)
Télécharger le fichier
