Active-Standby for High-Availability in FaaS - Archive ouverte HAL Access content directly
Conference Papers Year :
(1, 2) , (1) , (2) , (3)
1
2
3
Serverless computing is becoming more and more attractive for cloud solution architects and developers. This new computing paradigm relies on Function-as-a-Service (FaaS) platforms that enable deploying functions without being concerned with the underlying infrastructure. An important challenge in designing FaaS platforms is ensuring the availability of deployed functions. Existing FaaS platforms address this challenge principally through retrying function executions. In this paper, we propose and implement an alternative fault-tolerance approach based on active-standby failover. Results from an experimental evaluation show that our approach increases availability and performance compared to the retry-based approach.
Active-Standby-WoSC6.pdf (1.48 Mo) Télécharger le fichier
Dates and versions
hal-03043479 , version 1 (07-12-2020)
Identifiers
Cite
Yasmina Bouizem, Djawida Dib, Nikos Parlavantzas, Christine Morin. Active-Standby for High-Availability in FaaS. WoSC6 2020 - Sixth International Workshop on Serverless Computing, Dec 2020, Delft, Netherlands. pp.1-6, ⟨10.1145/3429880.3430097⟩. ⟨hal-03043479⟩
135 View
425 Download
Share
