A Regret Minimization Approach to Frameless Irregular Repetition Slotted Aloha: IRSA-RM
Wireless communications play an important part in the systems of the Internet of Things (IoT). Recently, there has been a trend towards long-range communications systems for the IoT, including cellular networks. For many use cases, such as massive machine-type communications (mMTC), performance can be gained by moving away from the classical model of connection establishment and adopting random access methods. Associated with physical layer techniques such as Successive Interference Cancellation (SIC), or Non-Orthogonal Multiple Access (NOMA), the performance of random access can be dramatically improved, giving rise to novel random access protocol designs. This article studies one of these modern random access protocols: Irregular Repetition Slotted Aloha (IRSA). Since optimizing its parameters is not an easily solved problem, in this article we use a reinforcement learning approach for that purpose. We adopt one specific variant of reinforcement learning, Regret Minimization, to learn the protocol parameters. We explain why it is selected, how to apply it to our problem with centralized learning, and finally, we provide both simulation results and insights into the learning process. The results obtained show the excellent performance of IRSA when it is optimized with Regret Minimization.
