A dynamic programming approach to segmented isotonic regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Omega Année : 2021
This paper proposes a polynomial-time algorithm to construct the monotone stepwise curve that minimizes the sum of squared errors with respect to a given cloud of data points. The fitted curve is also constrained on the maximum number of steps it can be composed of and on the minimum step length.
Segmented_isotonic_regression_Bucarey_et_al.pdf (907.56 Ko) Télécharger le fichier
hal-03046338 , version 1 (08-12-2020)
Víctor Bucarey, Martine Labbé, Juan M Morales, Salvador Pineda. A dynamic programming approach to segmented isotonic regression. Omega, 2021, ⟨10.1016/j.omega.2021.102516⟩. ⟨hal-03046338⟩
35 Consultations
123 Téléchargements
