Preprints, Working Papers, ...
Geometric algorithms for sampling the flux space of metabolic networks
Abstract : Systems Biology is a fundamental field and paradigm that introduces a new era in Biology. The crux of its functionality and usefulness relies on metabolic networks that model the reactions occurring inside an organism and provide the means to understand the underlying mechanisms that govern biological systems. Even more, metabolic networks have a broader impact that ranges from resolution of ecosystems to personalized medicine. The analysis of metabolic networks is a computational geometry oriented field as one of the main operations they depend on is sampling uniformly points from polytopes; the latter provides a representation of the steady states of the metabolic networks. However, the polytopes that result from biological data are of very high dimen- sion (to the order of thousands) and in most, if not all, the cases are considerably skinny. Therefore, to perform uniform random sampling efficiently in this setting, we need a novel algorithmic and computational framework specially tailored for the properties of metabolic networks. We present a complete software framework to handle sampling in metabolic networks. Its backbone is a Multiphase Monte Carlo Sampling (MMCS) algorithm that unifies rounding and sampling in one pass, obtaining both upon termination. It exploits an improved variant of the Billiard Walk that enjoys faster arithmetic complexity per step. We demonstrate the efficiency of our approach by performing extensive experiments on various metabolic networks. Notably, sampling on the most complicated human metabolic network accessible today, Recon3D, corresponding to a polytope of dimension 5 335 took less than 30 hours. To our knowledge, that is out of reach for existing software.
Document type :
Complete list of metadatas
https://hal.inria.fr/hal-03047049
Contributor : Elias Tsigaridas <>
Submitted on : Tuesday, December 8, 2020 - 4:41:55 PM
Last modification on : Sunday, December 13, 2020 - 3:07:33 AM
metabolic_networks.pdf
Identifiers
  • HAL Id : hal-03047049, version 1
  • ARXIV : 2012.05503
Citation
Apostolos Chalkis, Vissarion Fisikopoulos, Elias Tsigaridas, Haris Zafeiropoulos. Geometric algorithms for sampling the flux space of metabolic networks. 2020. ⟨hal-03047049⟩
Share
Metrics
Record views
76
Files downloads
83
