Direction-of-Arrival Estimation through Exact Continuous l20-Norm Relaxation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Signal Processing Letters Année : 2021
On-grid based direction-of-arrival (DOA) estimation methods rely on the resolution of a difficult group-sparse optimization problem that involves the l20 pseudo-norm. In this work, we show that an exact relaxation of this problem can be obtained by replacing the l20 term with a group minimax concave penalty with suitable parameters. This relaxation is more amenable to non-convex optimization algorithms as it is continuous and admits less local (not global) minimizers than the initial l20-regularized criteria. We then show on numerical simulations that the minimization of the proposed relaxation with an iteratively reweighted l21 algorithm leads to an improved performance over traditional approaches.
SPL-DOA_Soubies.pdf (503.6 Ko) Télécharger le fichier
hal-03047201 , version 1 (08-12-2020)
Emmanuel Soubies, Adilson Chinatto, Pascal Larzabal, João M T Romano, Laure Blanc-Féraud. Direction-of-Arrival Estimation through Exact Continuous l20-Norm Relaxation. IEEE Signal Processing Letters, 2021, 28, pp.16-20. ⟨10.1109/LSP.2020.3042771⟩. ⟨hal-03047201⟩
297 Consultations
344 Téléchargements
