On optimizing scalar self-rebalancing trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Balanced trees are pervasive and very often found in databases or other systems which are built around querying non-static data. In this paper, we show that trees implemented as a collection of pointers shows bad data locality, poor cache performance and suffer from a lack of parallelism opportunities. We propose an alternative implementation based on arrays. Both implementations appear to be equivalently efficient time-wise. This new layout exposes new parallelism opportunities which can be then exploited by an optimizing polyhedral compiler.
iannetta.2020.compas.pdf (176.62 Ko) Télécharger le fichier
hal-03048742 , version 1 (09-12-2020)
  • HAL Id : hal-03048742 , version 1
Paul Iannetta, Laure Gonnord, Lionel Morel. On optimizing scalar self-rebalancing trees. COMPAS 2020 - Conférence francophone d'informatique en Parallélisme, Architecture et Système, Jun 2020, Lyon, France. pp.1-7. ⟨hal-03048742⟩
84 Consultations
69 Téléchargements
