On the representation and learning of monotone triangular transport maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Foundations of Computational Mathematics Année : 2023
Transportation of measure provides a versatile approach for modeling complex probability distributions, with applications in density estimation, Bayesian inference, generative modeling, and beyond. Monotone triangular transport maps---approximations of the Knothe--Rosenblatt (KR) rearrangement---are a canonical choice for these tasks. Yet the representation and parameterization of such maps have a significant impact on their generality and expressiveness, and on properties of the optimization problem that arises in learning a map from data (e.g., via maximum likelihood estimation). We present a general framework for representing monotone triangular maps via invertible transformations of smooth functions. We establish conditions on the transformation such that the associated infinite-dimensional minimization problem has no spurious local minima, i.e., all local minima are global minima; and we show for target distributions satisfying certain tail conditions that the unique global minimizer corresponds to the KR map. Given a sample from the target, we then propose an adaptive algorithm that estimates a sparse semi-parametric approximation of the underlying KR map. We demonstrate how this framework can be applied to joint and conditional density estimation, likelihood-free inference, and structure learning of directed graphical models, with stable generalization performance across a range of sample sizes.
2022-07 On the representation and learning of monotone triangular transport maps.pdf (2.73 Mo) Télécharger le fichier
hal-03060198 , version 1 (30-01-2023)
Paternité
Ricardo Baptista, Youssef Marzouk, Olivier Zahm. On the representation and learning of monotone triangular transport maps. Foundations of Computational Mathematics, 2023, ⟨10.1007/s10208-023-09630-x⟩. ⟨hal-03060198v1⟩
181 Consultations
127 Téléchargements
