Big Genes, Small Effectors: Pea Aphid Cassette Effector Families Composed From Miniature Exons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Plant Science Année : 2020
Aphids secrete proteins from their stylets that evidence indicates function similar to pathogen effectors for virulence. Here, we describe two small candidate effector gene families of the pea aphid, , that share highly conserved secretory signal peptide coding regions and divergent non-secretory coding sequences derived from miniature exons. The KQY candidate effector family contains eleven members with additional isoforms, generated by alternative splicing. Pairwise comparisons indicate possible four unique KQY families based on coding regions without the secretory signal region. KQY1a, a representative of the family, is encoded by a 968 bp mRNA and a gene that spans 45.7 kbp of the genome. The locus consists of 37 exons, 33 of which are 15 bp or smaller. Additional KQY members, as well as members of the KHI family, share similar features. Differential expression analyses indicate that the genes are expressed preferentially in salivary glands. Proteomic analysis on salivary glands and saliva revealed 11 KQY members in salivary proteins, and KQY1a was detected in an artificial diet solution after aphid feeding. A single KQY locus and two KHI loci were identified in , the peach aphid. Of the genes that can be anchored to chromosomes, loci are mostly scattered throughout the genome, except a two-gene region (KQY4/KQY6). We propose that the KQY family expanded in through combinatorial assemblies of a common secretory signal cassette and novel coding regions, followed by classical gene duplication and divergence.
pdf (1.18 Mo) Télécharger le fichier
hal-03065308 , version 1 (28-05-2021)
Paternité
Matthew Dommel, Jonghee Oh, Jose Carlos Huguet-Tapia, Endrick Guy, Hélène Boulain, et al.. Big Genes, Small Effectors: Pea Aphid Cassette Effector Families Composed From Miniature Exons. Frontiers in Plant Science, 2020, 11, pp.1-11. ⟨10.3389/fpls.2020.01230⟩. ⟨hal-03065308⟩
49 Consultations
97 Téléchargements
