Results of the 2020 fastMRI Challenge for Machine Learning MR Image Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Medical Imaging Année : 2021
Sunwoo Kim
  • Fonction : Auteur
Geunu Jeong
  • Fonction : Auteur
Jingyu Ko
  • Fonction : Auteur
Yohan Jun
  • Fonction : Auteur
Hyungseob Shin
  • Fonction : Auteur
Dosik Hwang
  • Fonction : Auteur
Accelerating MRI scans is one of the principal outstanding problems in the MRI research community. Towards this goal, we hosted the second fastMRI competition targeted towards reconstructing MR images with subsampled k-space data. We provided participants with data from 7,299 clinical brain scans (de-identified via a HIPAA-compliant procedure by NYU Langone Health), holding back the fully-sampled data from 894 of these scans for challenge evaluation purposes. In contrast to the 2019 challenge, we focused our radiologist evaluations on pathological assessment in brain images. We also debuted a new Transfer track that required participants to submit models evaluated on MRI scanners from outside the training set. We received 19 submissions from eight different groups. Results showed one team scoring best in both SSIM scores and qualitative radiologist evaluations. We also performed analysis on alternative metrics to mitigate the effects of background noise and collected feedback from the participants to inform future challenges. Lastly, we identify common failure modes across the submissions, highlighting areas of need for future research in the MRI reconstruction community.
09420272.pdf (1.87 Mo) Télécharger le fichier
hal-03066150 , version 1 (15-12-2020)
hal-03066150 , version 2 (27-07-2021)
Matthew J. Muckley, Bruno Riemenschneider, Alireza Radmanesh, Sunwoo Kim, Geunu Jeong, et al.. Results of the 2020 fastMRI Challenge for Machine Learning MR Image Reconstruction. IEEE Transactions on Medical Imaging, In press, ⟨10.1109/TMI.2021.3075856⟩. ⟨hal-03066150v2⟩
308 Consultations
661 Téléchargements
