Sequential Sensor Placement using Bayesian Compressed Sensing for Source Localization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the sensor placement problem for an array designed for source localization. When it involves the identification of a few sources, the compressed sensing framework is known to find directions effectively thanks to sparse approximation. The present contribution intends to provide an answer to the following question: given a set of observations, how should we make the next measurement to minimize (some form of) uncertainty on the localization of the sources? More specifically, we propose a methodology for sequential sensor placement inspired from the "Bayesian compressive sensing" framework introduced by Ji et al. Our method alternates between a step of sparse source localization estimation, and a step to choose the sensor position that minimizes the covariance of the estimation error. Numerical results show that an array designed by the proposed procedure leads to better performance than sensors positioned at random.
0000241.pdf (404.98 Ko) Télécharger le fichier
hal-03070390 , version 1 (15-12-2020)
Milan Courcoux-Caro, Charles Vanwynsberghe, Cédric Herzet, Alexandre Baussard. Sequential Sensor Placement using Bayesian Compressed Sensing for Source Localization. EUSIPCO 2020 - 28th European Signal Processing Conference, Jan 2021, Amsterdam, Netherlands. pp.241-245, ⟨10.23919/Eusipco47968.2020.9287709⟩. ⟨hal-03070390⟩
146 Consultations
441 Téléchargements
