Complete Singularity Analysis for the Perspective-Four-Point Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2021
This paper is concerned with pose estimation and visual servoing from four points. We determine the configurations for which the corresponding Jacobian matrix becomes singular, leading to inaccurate and unstable results. Using an adequate representation and algebraic geometry, it is shown that, for any orientation between the camera and the object, there are always two to six singular locations of the camera in the generic case where the points are not coplanar, corresponding to the intersection of four cylinders. The particular case where the four points are coplanar is also characterized. Furthermore, some realistic example configurations are considered to substantiate the theory and to demonstrate failure cases in pose estimation and image-based visual servoing when the camera approaches a singularity.
main.pdf (976.86 Ko) Télécharger le fichier
hal-03070525 , version 1 (15-12-2020)
Beatriz Pascual-Escudero, Abhilash Nayak, Sébastien Briot, Olivier Kermorgant, Philippe Martinet, et al.. Complete Singularity Analysis for the Perspective-Four-Point Problem. International Journal of Computer Vision, 2021, 129 (4), pp.1217-1237. ⟨10.1007/s11263-020-01420-0⟩. ⟨hal-03070525⟩
387 Consultations
147 Téléchargements
