HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
Delaunay triangulations of generalized Bolza surfaces
Abstract : The Bolza surface can be seen as the quotient of the hyperbolic plane, represented by the Poincaré disk model, under the action of the group generated by the hyperbolic isometries identifying opposite sides of a regular octagon centered at the origin. We consider _generalized_ Bolza surfaces Mg, where the octagon is replaced by a regular 4g-gon, leading to a genus g surface. We propose an extension of Bowyer's algorithm to these surfaces. In particular, we compute the value of the systole of Mg. We also propose algorithms computing small sets of points on Mg that are used to initialize Bowyer's algorithm.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-03080125
Contributor : Monique Teillaud Connect in order to contact the contributor
Submitted on : Thursday, March 11, 2021 - 3:03:00 PM
Last modification on : Friday, February 4, 2022 - 9:00:13 AM
generalized_Bolza.pdf
Identifiers
  • HAL Id : hal-03080125, version 2
  • ARXIV : 2103.05960
Collections
Citation
Matthijs Ebbens, Iordan Iordanov, Monique Teillaud, Gert Vegter. Delaunay triangulations of generalized Bolza surfaces. 2021. ⟨hal-03080125v2⟩
Share
Metrics
Record views
165
Files downloads
98
