Non-triangular self-synchronizing stream ciphers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computers Année : 2022
In this paper, we propose an instantiation, called \textsf{Stanislas}, of a dedicated Self-Synchronizing Stream Cipher (SSSC) involving an automaton with finite input memory using non-triangular state transition functions. Previous existing SSSC are based on automata with shifts or triangular functions (T-functions) as state transition functions. Our algorithm Stanislas admits a matrix representation deduced from a general and systematic methodology called Linear Parameter Varying (LPV). This particular representation comes from the automatic theory and from a special property of dynamical systems called flatness.
Automatique
stanislas.pdf (1.49 Mo) Télécharger le fichier
hal-03081725 , version 1 (20-07-2021)
Julien Francq, Loic Besson, Paul Huynh, Philippe Guillot, Gilles Millérioux, et al.. Non-triangular self-synchronizing stream ciphers. IEEE Transactions on Computers, 2022, 71 (1), pp.134-145. ⟨10.1109/TC.2020.3043714⟩. ⟨hal-03081725⟩
619 Consultations
143 Téléchargements
