Graphene-Based Reconfigurable Intelligent Metasurface Structure for THz Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a graphene based reconfigurable intelligent metasurface structure is proposed for terahertz (THz) communication applications. The proposed structure consists of multilayer unit cells with a graphene radiating patch. By using different values of biasing voltages, the chemical potential (µc) of the graphene is changed which leads to have different reflected phases. Based on this property we are able to create different reflected phase distributions within the full structure metasurface array which can be controlled by coding pattern in processing units. The proposed unit cell can provide an acceptable reflection characteristic around 4.35 THz. In addition, by changing the biasing voltage, four states are generated which can transmit 1-bit and 2-bits data. The proposed metasurface structure has small size and high flexibility in controlling radiation patterns. The simulated results such as reflected phase distributions and reconfigurable radiation patterns show the effectiveness of the proposed design for THz communication.
Graphene-Based Reconfigurable Intelligent Metasurface Structure for THz Communications.pdf (1005.6 Ko) Télécharger le fichier
hal-03082069 , version 1 (18-12-2020)
  • HAL Id : hal-03082069 , version 1
Mohammad Ojaroudi, Valeria Loscrì. Graphene-Based Reconfigurable Intelligent Metasurface Structure for THz Communications. EuCAP 2021 - 15th European Conference on Antennas and Propagation, Mar 2021, Düsseldorf / Virtual, Germany. ⟨hal-03082069⟩
Collections
INRIA INRIA2
89 Consultations
369 Téléchargements
