Insensitizing controls for the heat equation with respect to boundary variations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal de l'École polytechnique — Mathématiques Année : 2022
This article is dedicated to insensitization issues of a quadratic functional involving the solution of the linear heat equation with respect to domains variations. This work can be seen as a continuation of [P. Lissy, Y. Privat, and Y. Simpor\'e. Insensitizing control for linear and semi-linear heat equations with partially unknown domain. ESAIM Control Optim. Calc. Var., 25:Art. 50, 21, 2019], insofar as we generalize several of the results it contains and investigate new related properties. In our framework, we consider boundary variations of the spatial domain on which the solution of the PDE is defined at each time, and investigate three main issues: (i) approximate insensitization, (ii) approximate insensitization combined with an exact insensitization for a finite-dimensional subspace, and (iii) exact insensitization. We provide positive answers to questions (i) and (ii) and partial results to question (iii).
Insensibilisation2.pdf (416.83 Ko) Télécharger le fichier
hal-03083177 , version 1 (18-12-2020)
hal-03083177 , version 2 (05-11-2022)
Sylvain Ervedoza, Pierre Lissy, Yannick Privat. Insensitizing controls for the heat equation with respect to boundary variations. Journal de l'École polytechnique — Mathématiques, 2022, Tome 9, pp.1397--1429. ⟨hal-03083177v2⟩
211 Consultations
113 Téléchargements
