REMI: Mining Intuitive Referring Expressions on Knowledge Bases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Luis Galárraga
  • Fonction : Auteur
  • PersonId : 1086583
Julien Delaunay
Jean-Louis Dessalles
A referring expression (RE) is a description that identifies a set of instances unambiguously. Mining REs from data finds applications in natural language generation, algorithmic journalism, and data maintenance. Since there may exist multiple REs for a given set of entities, it is common to focus on the most concise and informative (i.e., intuitive) ones. We present REMI, a method to mine intuitive REs on large knowledge bases. Our experimental evaluation shows that REMI finds REs deemed intuitive by users. Moreover we show that REMI is several orders of magnitude faster than an approach based on inductive logic programming.
paper_238.pdf (575.83 Ko) Télécharger le fichier
hal-03084627 , version 1 (03-02-2021)
Luis Galárraga, Julien Delaunay, Jean-Louis Dessalles. REMI: Mining Intuitive Referring Expressions on Knowledge Bases. EDBT 2020 - 23rd International Conference on Extending Database Technology, Mar 2020, Virtual Event, Denmark. pp.387-390, ⟨10.5441/002/edbt.2020.39⟩. ⟨hal-03084627⟩
118 Consultations
82 Téléchargements
