Weakly-unambiguous Parikh automata and their link to holonomic series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alin Bostan
  • Fonction : Auteur
  • PersonId : 831654
Arnaud Carayol
Cyril Nicaud
We investigate the connection between properties of formal languages and properties of their generating series, with a focus on the class of \emph{holonomic} power series. We first prove a strong version of a conjecture by Castiglione and Massazza: weakly-unambiguous Parikh automata are equivalent to unambiguous two-way reversal bounded counter machines, and their multivariate generating series are holonomic. We then show that the converse is not true: we construct a language whose generating series is algebraic (thus holonomic), but which is inherently weakly-ambiguous as a Parikh automata language. Finally, we prove an effective decidability result for the inclusion problem for weakly-unambiguous Parikh automata, and provide an upper-bound on its complexity.
LIPIcs-ICALP-2020-114.pdf (581.91 Ko) Télécharger le fichier
hal-03084639 , version 1 (21-12-2020)
Alin Bostan, Arnaud Carayol, Florent Koechlin, Cyril Nicaud. Weakly-unambiguous Parikh automata and their link to holonomic series. ICALP 2020 - 47th International Colloquium on Automata, Languages and Programming, Jul 2020, Saarbrücken, Germany. pp.114.1-114.16, ⟨10.4230/LIPIcs.ICALP.2020.114⟩. ⟨hal-03084639⟩
78 Consultations
147 Téléchargements
