A lightweight neural model for biomedical entity linking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Biomedical entity linking aims to map biomedical mentions, such as diseases and drugs, to standard entities in a given knowledge base. The specific challenge in this context is that the same biomedical entity can have a wide range of names, including synonyms, morphological variations, and names with different word orderings. Recently, BERT-based methods have advanced the state-of-the-art by allowing for rich representations of word sequences. However, they often have hundreds of millions of parameters and require heavy computing resources, which limits their applications in resource-limited scenarios. Here, we propose a lightweight neural method for biomedical entity linking, which needs just a fraction of the parameters of a BERT model and much less computing resources. Our method uses a simple alignment layer with attention mechanisms to capture the variations between mention and entity names. Yet, we show that our model is competitive with previous work on standard evaluation benchmarks.
Biomedical_Entity_Linking.pdf (1.19 Mo) Télécharger le fichier
hal-03086044 , version 1 (22-12-2020)
hal-03086044 , version 2 (25-05-2021)
  • HAL Id : hal-03086044 , version 2
Lihu Chen, Gaël Varoquaux, Fabian Suchanek. A lightweight neural model for biomedical entity linking. AAAI 2021 - The Thirty-Fifth Conference on Artificial Intelligence, Association for the Advancement of Artificial Intelligence, Feb 2021, Palo Alto (virtual), United States. pp.12657-12665. ⟨hal-03086044v2⟩
457 Consultations
272 Téléchargements
