An Analytic Propositional Proof System On Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2022
In this paper we present a proof system that operates on graphs instead of formulas. Starting from the well-known relationship between formulas and cographs, we drop the cograph-conditions and look at arbitrary (undirected) graphs. This means that we lose the tree structure of the formulas corresponding to the cographs, and we can no longer use standard proof theoretical methods that depend on that tree structure. In order to overcome this difficulty, we use a modular decomposition of graphs and some techniques from deep inference where inference rules do not rely on the main connective of a formula. For our proof system we show the admissibility of cut and a generalization of the splitting property. Finally, we show that our system is a conservative extension of multiplicative linear logic with mix, and we argue that our graphs form a notion of generalized connective.
LBF-LMCS.pdf (935.85 Ko) Télécharger le fichier
hal-03087392 , version 1 (23-12-2020)
hal-03087392 , version 2 (27-10-2022)
Matteo Acclavio, Ross Horne, Lutz Strassburger. An Analytic Propositional Proof System On Graphs. Logical Methods in Computer Science, 2022, 18 (4), ⟨10.46298/LMCS-18(4:1)2022⟩. ⟨hal-03087392v2⟩
89 Consultations
110 Téléchargements
