Synthesize MRI vocal tract data during CV production
A set of rtMR image transformations across time is computed during the production of CV that is afterwards applied to a new speaker in order to synthesize his/her CV pseudo rtMRI data. Synthesized images are compared with the original ones using image cross-correlation. 2 Purpose To be able to enlarge MRI speech corpus by synthesizing data.
