Explicit Mean-Square Error Bounds for Monte-Carlo and Linear Stochastic Approximation
This paper concerns error bounds for recursive equations subject to Markovian disturbances.Motivating examples abound within the fields of Markov chain Monte Carlo (MCMC) andReinforcement Learning (RL), and many of these algorithms can be interpreted as special casesof stochastic approximation (SA). It is argued that it is not possible in general to obtain aHoeffding bound on the error sequence, even when the underlying Markov chain is reversibleand geometrically ergodic, such as the M/M/1 queue. This is motivation for the focus on meansquare error bounds for parameter estimates. It is shown that mean square error achieves theoptimal rate ofO(1/n), subject to conditions on the step-size sequence. Moreover, the exactconstants in the rate are obtained, which is of great value in algorithm design.
