Safe Overclocking for CNN Accelerators through Algorithm-Level Error Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems Année : 2020
In this article, we propose a technique for improving the efficiency of convolutional neural network hardware accelerators based on timing speculation (overclocking) and fault tolerance. We augment the accelerator with a lightweight error detection mechanism to protect against timing errors in convolution layers, enabling aggressive timing speculation. The error detection mechanism we have developed works at the algorithm-level, utilizing algebraic properties of the computation, allowing the full implementation to be realized using high-level synthesis tools. Our prototype on ZC706 demonstrated up to 60% higher throughput with negligible area overhead for various wordlength implementations.
FINAL VERSION.pdf (1.16 Mo) Télécharger le fichier
hal-03094811 , version 1 (23-06-2021)
Thibaut Marty, Tomofumi Yuki, Steven Derrien. Safe Overclocking for CNN Accelerators through Algorithm-Level Error Detection. IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, 2020, 39 (12), pp.4777 - 4790. ⟨10.1109/TCAD.2020.2981056⟩. ⟨hal-03094811⟩
75 Consultations
231 Téléchargements
