Toward Safe and Efficient Reconfiguration with Concerto - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science of Computer Programming Année : 2021
For large-scale distributed systems that need to adapt to a changing environment, conducting a reconfiguration is a challenging task. In particular, efficient reconfigurations require the coordination of multiple tasks with complex dependencies. We present Concerto, a model used to manage the lifecycle of software components and coordinate their reconfiguration operations. Concerto promotes efficiency with a fine-grained representation of dependencies and parallel execution of reconfiguration actions, both within components and between them. In this paper, the elements of the model are described as well as their formal semantics. In addition, we outline a performance model that can be used to estimate the time required by reconfigurations, and we describe an implementation of the model. The evaluation demonstrates the accuracy of the performance estimations, and illustrates the performance gains provided by the execution model of Concerto compared to state-of-the-art systems.
concerto-scp.pdf (1014.45 Ko) Télécharger le fichier
hal-03103714 , version 1 (08-01-2021)
Maverick Chardet, Hélène Coullon, Simon Robillard. Toward Safe and Efficient Reconfiguration with Concerto. Science of Computer Programming, 2021, 203, pp.1-31. ⟨10.1016/j.scico.2020.102582⟩. ⟨hal-03103714⟩
351 Consultations
424 Téléchargements
